ESRI example code in Create a FeatureLayer from a shapefile adds zipped shapefile into map.
This code uses ArcGIS REST API Generate to create the feature collection, but it is limited and can't create if total recors number is greater than 4000.
So, I want to analyze the zipped shapefile prior to generating features using Generate operation, in order to know the number of records, either total, or better - per layer.
My questions are:
I'll appreciate help,
Michael
Solved! Go to Solution.
I assume it's impossible, becaue zip file could be analysed only after esri had read it, and from WAB (Developer Edition) Web Application, if number of total records > 4000, esri can't read it, since esri had limited the "generate" service to limit of 4000 records.
Michael
Michael
