onReceiveData from the Search widget is not working.
1120
8
08-13-2020 01:23 PM
MartinOwens1
Occasional Contributor II
Has anyone had an issue trying to receive data in the Search widget? I have attempted to publish from multiple other widgets with no luck. Is there something I'm missing on this particular widget?
  startup: function() {
		this.fetchData();
		this.fetchDataByName('Query');
        this.inherited(arguments);
     onReceiveData: function(name, widgetId, data) {
		if (parID.target === "Search") {
		parID = data;
		console.log('Search ParID data from Query ' + parID.data);
MartinOwens1
For anyone that encounters this issue in the future here is how to make the Search widget receive data with the OnReceiveData method:
 postCreate: function() {
		this.listenWidgetIds.push('Widget ID');
RobertScheitlin__GISP
Martin,
   the Search widget already has an onReceiveData function... Did you replace that functions contents with what you show above?
MartinOwens1
Yeah I just replaced it with what I pasted here. It's not in the code twice.
CarlosNantes
New Contributor III
It seems to me that the order that the widgets are been created is causing the problem. Probably Search widget is been created before the other widgets. If this is the case, it seems that this.fetchDataByName('Query') will not find the widget Query because it doesn't exists yet.
Maybe you should try to use dojo/topic module to solve this problem.  You'll probably do something like this:
//Search/Widget.js
   topic.subscribe('query', lang.hitch(this, this.whenQueryPublishesDo));
whenQueryPublishesDo: function(data){
   //...process data
   console.log(data.result)
//Query/Widget.js
define([
   'dojo/topic',
]), function(
    topic,
someMethod: function() {
   var data = {
     result : {
   topic.publish('query', data);
MartinOwens1
I would think it should still fetch data since I'm calling the fetchData(); method on line 2. The results are published after both widgets are created.
MartinOwens1
The end goal here is to send a value to the Search dijit and execute the search function.
MartinOwens1
Has anyone been able to test this and see if they can receive data in the Search widget?
Martin,
   After testing I can confirm you are correct that the Search widget is Not receiving data.
MartinOwens1
