flow direction (spatial analyst) tool error
1829
08-10-2020 11:11 AM
Md__Rakib_Hossain
I have enabled all the extensions in the customize toolbar including spatial analyst tool. But whenever I run this Flow Direction tool formy DEM, Flow Direction tool shows some error. Please see the attached screenshots for the input and error messages. Please HELP. Error message for Flow directionInput Data
DanPatterson
MVP Esteemed Contributor
What is this about image server not having the right license?
Do you have licenses requiring server access?
If you aren't working with a local install, you will have to check on that end
... sort of retired...
Md__Rakib_Hossain
Dan, Thanks for your reply.
But my ArcGIS v10.8 is licensed. Is license requiring server access differs from the ArcGIS license? If yes, then how may I get it?
