Increase vertical exaggeration
1025
08-09-2020 06:34 PM
RobertSchwartz
In local scene, Arc GIS Pro 2.6, 3d layer is flat. How can I increase the vertical exaggeration?
DanielChantlos
Hi Robert,
Could you provide some further context? Is this a point/polyline/polygon feature? If you select the layer in the Table of Contents and access the Appearance tab, you should see some extrusion options. I would be glad to assist you with this.
RobertSchwartz
That was true in ArcMap but not in my copy of ArcGIS Pro 2.6. The only option for vertical exaggeration is via the Elevation Sources/Ground.
No ability to vertically exaggerate in 2D or 3D featuresno vertical exaggeration option in 3D
