Difference between red and green vertexes on a polygon
1086
08-09-2020 12:40 AM
GabrielMesa
I'm editing some shapefiles (not originally made by me) , specifically changing the vertexes of some polygons and I realize when some of the vertexes look red while the majority look green, any reason as to why some are different coloured?
DanPatterson
MVP Esteemed Contributor
The start and end vertex of a single polygon is highlighted in red.  They will share the same coordinate.
I don't have any shapefiles, but are you getting red highlighted points at other locations?
... sort of retired...
DanPatterson
GabrielMesa
No, you are correct  hadn't actually checked but indeed there's only 1 red vertex per polygon, interesting little fact thank you, couldn't find information about it anywhere
DavidPike
MVP Frequent Contributor
GabrielMesa
Thank you! altough it's kind of a vague statement imo, current could just mean the one you're trying to move but it's not the case
