plot array of different pictureSymbol
999
08-06-2020 04:51 AM
rsharma
Hi i am trying to add muliple picture marker symbol  in my app where x and y coordinates of different type of markers come from db like low signal and high signal
Now i am trying to add it in my map like below but it doesn't show up with markers
import QtQuick 2.7
import QtQuick.Controls 2.1
import QtQuick.Controls.Material 2.1
import QtQuick.XmlListModel 2.0
import ArcGIS.AppFramework 1.0
import Esri.ArcGISRuntime 100.2
Item {
    //! [GOSymbols MapView]
    // Map view UI presentation at top
    MapView {
        anchors.fill: parent
        rotationByPinchingEnabled: true
        zoomByPinchingEnabled: true
        Map {
            BasemapOceans {}
            initialViewpoint: viewPoint
        GraphicsOverlay {
        GraphicsOverlay{
    }    //! [GOSymbols MapView]
// the center of the mapview
    ViewpointCenter {
        center: Point {
            x: 172.49307355493
            y: -43.4810759934974
            spatialReference: SpatialReference {
                wkid: 4326
        targetScale: 288895.277144
    PictureMarkerSymbol {
        url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Recreation/FeatureServer/0/images/e82f744ebb069bb35b234b3fea46deae"
        width: 38.0
        height: 45.0
        offsetX: 0
        offsetY: 25
    SimpleFillSymbol {
        style: Enums.SimpleFillSymbolStyleSolid
        color: Qt.rgba(1, 1, 0, 0.4)
        SimpleLineSymbol {
            style: Enums.SimpleLineSymbolStyleSolid
            color: "blue"
            width: 2.0
             antiAlias: true
    //! [GOSymbol line symbol]
    // add all the graphics to the graphics overlay
    // create each graphic type and then add them to the overlay at a time
    // alternatively you can create all of them and store in a list and add all of them
    // by calling appendAll and pass in the list.
    Component.onCompleted: {
        // add boat route
        graphicsOverlay.graphics.append(createGraphic(createBoundaryRoute(), fillSymbol));
        markergraphicOverlay.graphics.append(createGraphic(addMarker(), markersymbol));
        // add the nesting ground
    //! [GOSymbol createGraphic]
    // create and return a graphic
    function createGraphic(geometry, symbol) {
        var graphic = ArcGISRuntimeEnvironment.createObject("Graphic");
        graphic.geometry = geometry;
        graphic.symbol = symbol;
        console.log((graphic.geometry.json));
        return graphic;
    //! [GOSymbol createBoatRoute]
    // create the boat route
    function createBoundaryRoute() {
        // create polyline using json
        return ArcGISRuntimeEnvironment.createObject("Polygon", {"json": boundaryJson});
    function addMarker(){
         return ArcGISRuntimeEnvironment.createObject("Point",{"x":172.49307355493,"y": -43.4810759934974, "spatialReference": { wkid: 4326 } });
    //! [GOSymbol boatRouteJson]
    property var boundaryJson : {"rings":[[[172.4864177167, -43.4807531333], [172.4947915167, -43.4814620167], [172.4942547333, -43.4809051667], [172.4937289833, -43.4799734], [172.4935005833, -43.4796536333], [172.4934417167, -43.4795711167], [172.486064, -43.4807159833], [172.4860340333, -43.4807206667], [172.4864177167, -43.4807531333]]],
                                  "spatialReference":{"wkid":4326}}
LucasDanzinger
Esri Frequent Contributor
I see an issue in your addMarker function. Point's spatialReference property expects a SpatialReference object, but the way you've got it, it passes in a json of wkid: 4326. Try instead:
return ArcGISRuntimeEnvironment.createObject("Point",{"x":172.49307355493,"y": -43.4810759934974, "spatialReference": SpatialReference.createWgs84() });
Or
const sr = ArcGISRuntimeEnvironment.createObject(“SpatialReference”, { “wkid”: 4326};
return ArcGISRuntimeEnvironment.createObject("Point",{"x":172.49307355493,"y": -43.4810759934974, "spatialReference": sr });
LucasDanzinger
Or
