Changing license type takes for ever in 2.6
335
08-05-2020 09:56 PM
ModyBuchbinder
Trying to change license type (from named user to float) takes a few minutes in 2.6
The scroll just does not opened.
Works fine (on the same machine) in 2.5
Anybody else see this problem?
Mody
AmnoyAm
Mody,
I've tested the transition to different licensing type, including to and from Concurrent Use license, and have not experience your issue.  Concurrent Use license will take a few seconds to display but it shouldn't take more than a few minutes.  Can you see if this occurs on another machine?  If so, I recommend creating a fiddler log for each version and contact technical support.  This way the right people can review your logs for possible issues.
JoshuaBixby
MVP Esteemed Contributor
I am seeing something similar as Mody Buchbinder‌, not quite a few minutes, but it does seem to take 30-60 seconds in Pro 2.6.  It hasn't been enough of an issue yet to spend the time to investigate.
