Dimensions layer
324
08-04-2020 08:50 PM
MarkHolm
Is there a way to show dimensions of a geometry with a dimension line, arrowheads, extension line, extension line offset, etc. I didn't see anything built in so I was trying to recreate a simple version of this with polylines but the using the SimpleMarkerSymbolStyleTriangle as the ends doesn't rotate and the end isn't where it needs to be so it doesn't look correct.
Let me know if there is anything that might be built in or in the works some way of annotation like this.
Thank You
Tags (1)
LucasDanzinger
Esri Frequent Contributor
Dimensions aren't supported at the moment, but we are considering adding support for them.
