Remove Result Graphic following Search - ArcGIS API for JS v4.16
3192
18
07-27-2020 06:58 AM
PaulMcCord
I'm using the Search widget to allow users to search for parcel addresses. The Search process is working properly except it places a blue graphic on the map even though I'm specifying that I don't want a graphic. I'm assigning my own symbology to the selected feature (the orange border in the below image), and I don't want the additional blue graphic that is being forced on the selected feature.
Selected feature following search
Here is my code for the search process:
//Create search tool to search addresses
    const searchTool = new Search({
        view: myView,
        sources: [
                layer: parcelLyr,
                searchFields: ["propstreet"],
                displayField: "propstreet",
                placeholder: "example: 500 Griswold",
                suggestionsEnabled: true,
                //autoNavigate: true,
                resultGraphicEnabled: false
        container: addressSearchBar,
        includeDefaultSources: false,
    searchTool.on("select-result", function(event){
        console.log("location was chosen ", event)
        long = event.result.feature.geometry.centroid.longitude + 0.003
        lat = event.result.feature.geometry.centroid.latitude
        myView.center = [long, lat];
        myView.zoom = 16
        console.log("geometry: ", event.result.feature.geometry)
        selectedParcel = event.result.feature
        createHighlightedParcel();
I create my own symbology in the createHighlightedParcel() function at the end. My understanding is that setting resultGraphicEnabled to false should remove the result graphic. Am I wrong about this? Is there another way to prevent the result graphic?
Thank you
PaulMcCord
After speaking with tech support, we've found a solution for my issue. The result object is still added to the map, but I changed the opacity for the fill and the outline to be completely transparent. The highlightOptions within the MapView took care of the issue:
myView = new MapView({
        container: "map_canvas",
        map: myMap,
        center: mapCenter,  //Center map on downtown Detroit
        zoom: zoomLevel,
        //Exclude the zoom widget from the UI
        ui: {
          components: ["attribution"]
        constraints: {
          rotationEnabled: false
        //Highlight options to hide Search result from map
        highlightOptions:{
            color: [ 0,0, 0, 0.0 ],
            fillOpacity: 0.0
RobertScheitlin__GISP
Paul,
   The search widgets graphic is orange when the
resultGraphicEnabled: true
So the cyan color you are seeing is from the popup selection.
PaulMcCord
Thanks Robert. I'm not sure if I understood your response. I set the popupEnabled option to 'false', but I'm still seeing the cyan symbology when the Search widget finishes. Is there another option I need to set?
Paul,
  It is something in your code base, because when I set the resultGraphicEnablerd to false in the sample that allows for searching a polygon it does not have a cyan or orange graphic in the map (as expected). So that is why I thought that some where in your code you are using the popup (which applies a cyan fill to the selected graphic).
PaulMcCord
The strange thing is that when I revert back to ArcGIS API for JS v 4.11, the cyan feature isn't added. As soon as I move to 4.12 or more recent, it's added and I can't get it to go away.
Is there something I can do with the resultGraphic parameter or do you have any examples of using the resultGrahic in the Search tool? At this point, I'm willing to just style it in a way that it is hidden from view. The documentation for Search says this about the resultGraphic, but I can't find any examples online of how to set this up:
The graphic used to highlight the resulting feature or location.
A graphic will be placed in the View's graphics for layer views that do not support the highlight method.
Paul,
   Have you tried view.graphics.removeAll()?
PaulMcCord
view.graphics.removeAll() doesn't remove it from the map view. When I console.log view.graphics.length, there are no graphics even before I try to remove any graphics. I'm at a loss as to why this graphic is appearing and how to remove it.
Paul,
   Have you tried to see if the Seach widgets resultGraphic is a graphic or is it null?
PaulMcCord
Here's my process that runs after the Search tool executes. I put this process together to center the Map View on the result.
        myView.zoom = 16
        //Opens Parcel Info Panel and places results in panel
        if ($("#parcelInfoPanel").css("visibility") === "hidden"){
            console.log("in the show pacel info panel function")
            showParcelInfoPanel();  //Reveals panel with parcel information
        console.log(selectedParcel)
        populateParcelPanel(selectedParcel);  //Grabs parcel information from parcel features for the parcel panel
I'm grabbing the result of the search in the second line.
Then, when I unpack that object it the console, by clicking on target, then resultGraphic, the value of resultGraphic is an object. Here is a screenshot of my console:
Result graphic details
Then try
resultGraphic.layer.removeAll();
