How to disable logging in the runtime
864
07-23-2020 12:43 AM
IonutAlixandroae1
Hi all.
I have a very dumb question regarding the runtime, version 100.8.
I have developed a small application and compiled it to a runnable jar. Whenever I am running the java code or the jar in cmd, before getting printed what I need, the first 2 messages printed are : "Initializing... " and "Java version : 11.0.7 (Oracle Corporation) amd64" (see print sceen below)
Is there a way to disable/supress this? I suspect this is coming from within the runtime
Rachael_Ellen
Thank you for your question: you are correct, those messages do indeed come from within ArcGISRuntime, and it's not currently possible to turn them off. Is there a reason that you would like to see this turned off, or to have the option not to display this message? We'd be interested to hear!
Many thanks,
Rachael
IonutAlixandroae1
Hi Rachel,
Thanks a lot for your reply!
Well, my reason is that created a small application and compiled it as a runnable jar (no GUI), and I`m calling this jar as a subprocess in a NodeJS API, and here I`m trying to catch the output from the jar and parse it (the JSON). Of course, without skipping those messages, my NodeJS API cannot parse a string like  "Initializing... " and "Java version : 11.0.7 (Oracle Corporation) amd64" because it`s not a JSON structure.
I was able to avoid/skip the first 2 messages and only catch the real output (JSON output) from the jar but I was wondering if there is a way to disable it because for me and in this case it`s not important. I`m only interested to see the output message from my application.
I hope you understood my situation/reason
Ionut
