Clear graphics after queryTask
450
07-22-2020 03:00 PM
LoriEmerson_McCormack
How do I clear graphics when I close my popup template from a queryTask result?  I would expect the symbol to be associated with the "parcelResults" because that is where I set the symbol, but it didn't show in the map until I used the map.add(graphicsLayerParcel).
function doQueryParcel(paramParcelID) {
// Clear the results from a previous query
graphicsLayerParcel.removeAll();
paramsQuery.where = "PID_NUM = '" + paramParcelID + "'";
// executes the query and calls getResultsParcel() once the promise is resolved
// promiseRejected() is called if the promise is rejected
qTaskParcel.execute(paramsQuery)
.then(getResultsParcel)
.catch(promiseRejected);
} // end function doQueryParcel()
function getResultsParcel(response) {
map.add(response);
// Loop through each of the results and assign a symbol and PopupTemplate
// to each so they may be visualized on the map
var parcelResults = response.features.map(function (feature) {
//var parcelResults = arrayUtils.map(response.features, function (feature) {
// Sets the symbol of each resulting feature
feature.symbol = fillSymbolSingleParcel;
feature.popupTemplate = tplParcel;
return feature;
graphicsLayerParcel.addMany(parcelResults);
map.add(graphicsLayerParcel );
var parcelExtent = response.features[0].geometry.extent.clone().expand(2);
// animate to the results after they are added to the map
view.goTo(parcelExtent).then(function () {
view.popup.open({
features: parcelResults,
featureMenuOpen: true,
updateLocationEnabled: true
} // end function getResultsParcel()
Never mind.  I had a brain freeze.  Here is what can clear the graphics when the popup is closed:
watchUtils.whenFalse(view.popup, "visible", function () {
view.graphics.removeAll();
