QuickCapture Project Save As Error
1018
07-21-2020 01:10 PM
kmsmikrud
Occasional Contributor III
Today I am trying to use the 'Save as' option in the ArcGIS QuickCapture Designer to save a copy of my current project. When I click on 'Save as' and give it a name I consistently get an error. "Can't save project due to an unknown error  Please try again. If the error persists, please contact Esri Support."
Is there a recommendation of something I can check that might be causing this error prior to contacting Esri support? I've tried saving with and without 'Make a copy of the layers' and still get the error
Thanks in advance for your help,
Kathy
kmsmikrud
This is an update. The QuickCapture team reported there was a glitch in ArcGIS Online that was causing the save as function to no longer work. The team fixed the issue.
Mandy_Li
Hi Kathy,
What is your portal environment? Can you help look into the console of your browser and what is the error message showing there? For example, in google chrome, press F12, start over the save as process you had in Designer, when the error occurs, check the messages in your Console dialog. Please send your project screenshots and console messages to QuickCapture@esri.com and we will take a look.
Mandy
kmsmikrud
Hi Mandy,
Thanks for the quick reply. My project and layers are all in AGOL. I wasn't able to see an error in google chrome, but was able to Firefox. I'll send the screenshot to the email you provided.
Thanks so much for your help,
Kathy
kmsmikrud
