AnsweredAssumed Answered
Access private map in ARCGIS studio without login to arcgis online
Question asked by rajni_sharma on Jul 20, 2020
Latest reply on Jul 22, 2020 by ESoekianto-esristaff
Hi i want to access my maps(private). in my application , but they always ask for the login credentials.
I want to make it accessible without login.
DO I need to add credential of username and password and token,
How to generate token in arcgis to pass in credentials, to access private map without login
I used this example to write the below code https://community.esri.com/message/908803-re-simple-app-with-private-webmap?commentID=908803#comment-908803 .
This is my code below:-
import QtQuick 2.6
import QtQuick.Controls 2.1
import QtQuick.Controls 1.4
import QtQuick.Layouts 1.1
import QtPositioning 5.3
import QtSensors 5.3
import ArcGIS.AppFramework 1.0
import ArcGIS.AppFramework.Controls 1.0
import Esri.ArcGISRuntime 100.6
import Esri.ArcGISRuntime.Toolkit.Dialogs 100.1
import "assets/js/backend.js" as Backend
App{
    width: 400
    height: 800
    property real scaleFactor: AppFramework.displayScaleFactor
    property string portalUrl: "https://arcgis.com/sharing/rest/content/items/";
    property string itemID: "mymapid"
    //header bar
    Rectangle {
        anchors {
            left: parent.left
            right: parent.right
            top: parent.top
        height: 50 * AppFramework.displayScaleFactor
        color: app.info.propertyValue("titleBackgroundColor", "red")
        Text {
            anchors.centerIn: parent
            text: app.info.title
            color: app.info.propertyValue("titleTextColor", "white")
            font {
                pointSize: 18
            wrapMode: Text.WrapAtWordBoundaryOrAnywhere
            maximumLineCount: 2
            elide: Text.ElideRight
            horizontalAlignment: Text.AlignHCenter
    }//End Rectangle header
    MapView {
        property real initialMapRotation: 0
        anchors {
            left: parent.left
            right: parent.right
            top: titleRect.bottom
            bottom: parent.bottom
        rotationByPinchingEnabled: true
        zoomByPinchingEnabled: true
    // add a basemap
    Map {
        item: PortalItem {
            portal: portal
            itemId: itemID
        //initUrl: portalUrl + itemID
    }//End Mapview
    //! [PortalUserInfo create portal]
    Portal {
        credential: Credential {
            oAuthClientInfo: OAuthClientInfo {
                oAuthMode: Enums.OAuthModeUser
                clientId: "myclientid" //replace
        Component.onCompleted: {
            load();
            //fetchLicenseInfo();
        onLoadStatusChanged: {
            if (loadStatus === Enums.LoadStatusFailedToLoad)
                retryLoad();
    AuthenticationView {
        authenticationManager: AuthenticationManager
Outcomes
