Is there a way to easily export a selection from multiple layers into multiple shapefiles?
8357
07-16-2020 08:21 AM
MatthewBeal
Occasional Contributor III
I have been given a request to export ALL GIS features that we have for a certain geographic area only. We have quite a lot of layers, so I would like to find a quicker way to do this short of exporting each layer one at a time. Does anyone know of a tool that will let you batch export selected features to a new shapefile using the same name as the input feature classes?
Tags (3)
Robert_LeClair
Esri Notable Contributor
One quick and easy way is to run the Feature Class to Shapefle in Batch mode.  To do this, search for Feature Class to Shapefile.  Right-click and select "batch."  From there, fill out the Input Parameters for your series of shapefiles (in my case in the Map View with selections).  Then identify the Batch Output folder you wish the selected records to go to (in my case, a test folder under my c:/temp directory).  Voila!  Same name as the original shapefiles.
DavidPike
MVP Frequent Contributor
with a script - arcpy.listLayers(mxd) then copy etc or the Clip and Ship tool.
Robert_LeClair
MatthewBeal
I have no idea that how this solution slipped by me! I ended up finding a second way to accomplish this as well using the "Extract" tool in ArcGIS Desktop. This way seems a bit more straightforward, so I will use it next time. Thank you!
StevenNicholl1
Thank you this is was very helpful, 500 layers needed to be converted and you saved me so much time, and carpal tunnel
