Pycharm not seeing ArcGIS PRO licenses
762
07-14-2020 01:59 PM
JamesWhite5
New Contributor III
I am trying to take the footprint of rasters using the 3d analyst tool Raster Domain. I can run it in PRO just fine, so I know it is licensed, but when I run it from pycharm, it returns an error stating that the too is not licensed. I have tried running the script with PRO open as well and still get the error. I do have the ArcGIS PRO python folder in the correct place in pycharm settings. I am not using a single user license.  I am using a license server.
Thanks.
DanPatterson
MVP Esteemed Contributor
There are lots of posts on issues with pycharm but Shawn Walbridge's post seems to be the most upvoted
https://community.esri.com/message/796296-re-can-arc-gis-pro-intergrate-with-jetbrains-pycharm?comme...
... sort of retired...
JoshuaBixby
Start by writing a basic script that imports ArcPy.  Knowing whether you can import ArcPy or not will help direct you to where you need to look next.
DanPatterson
JamesWhite5
New Contributor III
Ok, thank you.  I will try these out.  I know I set the environment according to the instructions in the Python for Everyone course, but maybe it wasn't set for all projects.
