AnsweredAssumed Answered
TopoToRaster failing within model, fine outside
Question asked by rsm_ddms on Jul 10, 2020
Latest reply on Jul 10, 2020 by rsm_ddms
I thought that I was imagining this, but I've tried it several times. When I run "TopoToRaster" from within a model, the output does not display. It loads into the map, when I zoom to it, I am sent where I expect to be. There are no errors. The values in the render are what I expect. Coordinate System is fine. Spatial extent is fine. There are columns and rows. The file has a reasonable size.
I've symbolized several different ways - stretch, unique values, etc...
It will not show.
When I run the tool from the toolbox, it works fine. I see the output and every single parameter I check is identical the output from within the model that I am unable to see.
Anyone else experience this?
Thank you,
Randy
Outcomes
