editing circles
1608
07-07-2020 05:35 AM
Shahzada_Raees_IqbalGillani
I am new to ArcGIS Pro and I had a basic question that I could not find via google.
I have created a feature and then dragged it on the map as a layer. Then created a circle with radius x, after my circle has been created, I would now like to edit this radius to be something other than x. How can I do this?
Please help.
Kind regards,
Raees
LukasFalk
Hello Raees,
After doing a bit of testing it doesn't look like you can reshape the circle based on a specified radius after it has already been created.  You can within the Modify Features pane use the Scale tool to alter the size of the circle, but not by specifying a radius.
I think the best course of action for you would be to just create a new circle with the new radius value you want.  You can find some additional documentation about creating circle polygons at the URL below.
Create circles and ellipses—ArcGIS Pro | Documentation
I hope this helps!
LukasFalk
Hello Raees,
I hope this helps!
Hi Lukas,
Thank you for taking the time to look into this.
I'm saddened to hear that there isn't a way, but alas I took your suggestion to just delete and create a new circle (or alternatively have just been using ctrl + z to undo and re-draw the circle with desired radius).
Thank you for your help!
