Remove a layer using ArcGis Pro SDK 2.4
1573
5
07-06-2020 06:27 PM
TOSHKIMAKINO
How do you remove FeatureClass from file geodatabase programmatically using the ArcGIS Pro SDK?
Thank´s
RichRuh
DDL (data definition language) operations are not natively supported in the Pro SDK.  You need to use the geoprocessing routines to run the "Delete" tool to delete the dataset.
I hope this helps,
--Rich
RichRuh
I hope this helps,
--Rich
TOSHKIMAKINO
Hi Rich,
Thank you for answering my question.
I'll give "Delete" tool a try.
Wolf
by Esri Regular Contributor
There is a sample that deletes a table from a File Geodatabase: Edit Operation Row Event
You might be able to use this snippet from this sample:
QueuedTask.Run(async() =>
    //find layer and derive geodatabase
    var cpLayer = MapView.Active.Map.FindLayers("CrowdPlanning").FirstOrDefault() as FeatureLayer;
    var geodatabase = cpLayer.GetFeatureClass().GetDatastore() as Geodatabase;
    //Advise
    //Delete the editlog table
    var mva = Geoprocessing.MakeValueArray(geodatabase.GetPath().AbsolutePath,"EditLog");
    await Geoprocessing.ExecuteToolAsync("Delete_management", mva);
TOSHKIMAKINO
Hi Wolfgang,
Thank you.
It's working perfectly.
qingluo1
Hi Wolf,
How do you remove WMTS layer using the ArcGIS Pro SDK?
Thank´s
