Deploy Custom widgets on Windows 10
707
5
06-30-2020 02:58 AM
AmineMarkaoui
Hello everyone,
I have developed some widgets on WAB (Developer Edition) and I want to deploy them to our Arcgis Online portal,
currently I am using windows 10 which it is my development environment and I want it also for the moment to be my production environment.
I have found this link providing the requirements for the server to be used to publish the widgets:
Add custom widgets—Portal for ArcGIS | Documentation for ArcGIS Enterprise
1st Question: Can I use a windows 10 instead of a windows server ?
2nd: Is there any resource where to find the steps listed above practically executed ?
thank you in advance
Rebecca Strauch, GISPRobert Scheitlin, GISP
RobertScheitlin__GISP
Amine,
   If you are able to install Portal on that machine, then yes.
Amine,
   Deploying custom widgets to AGOL is NOT a supported workflow. Custom widget can only be used in WAB Developer or on premise Portal (Enterprise ArcGIS).
AmineMarkaoui
Thank you mister Robert,
In case I want to deploy custom widgets on Portal, is that possible even though I'm using a win 10 ?
Amine,
AmineMarkaoui
thank you mister Robert,
Actually I am bit confused, Is it impossible for me to use custom widgets on AGOL and I am obligated to work JUST with what is already there ?
If it possible but there is some downsides, can you tell me about them so I can get a clearer idea?
thank you for your time
As I stated already yes you are limited to what is available out of the box when using AGOL. Custom widget are only available for WAB Developer edition and Portal.
