Visual Differences from 100.7 to 100.8
1014
06-28-2020 02:54 PM
MattRickard
When we upgraded from 100.7 to 100.8, we immediately noticed a degradation in visual quality.
See the two examples below.  Notice the edges of the black hexagon.
We see this on multiple symbols/types.
I've attached a minimal mmpk, in case that helps.
Is there anything we can do about this, or will this be fixed soon?
100.7
100.8
MichaelBranscomb
Esri Frequent Contributor
The visual difference is caused by a change in v100.8 where we now use the Dynamic RenderingMode for Feature Layers with point geometry when the Map has a ReferenceScale set. Thanks for reporting the issue above - we're investigating and hope to be able to resolve this case in an upcoming release.
To restore the original behavior you can set FeatureLayers to use the **Static** RenderingMode either by setting the FeatureLayer.RenderingMode Property on a per-layer basis or by setting the Map.LoadSettings Property / LoadSettings.PreferredPointFeatureRenderingMode Property. In both cases the property should be set to FeatureRenderingMode Enumeration value Static.
Mike
MattRickard
Thanks Mike.
This workaround fixed the problem for now.
A few notes:
  • I had to set the RenderingMode to "Static", not Dynamic
  • I couldn't get it to work for all layers by setting it on the map.
    • Map.LoadSettings.PreferredPointFeatureRenderingMode
  • I had to set it on each individual FeatureLayer.
MichaelBranscomb
Apologies for the misdirection, I replied while in the midst of an in-depth discussion about Dynamic and Static. I've updated my comment above (Static being the all important mode in this case).
Mike
MichaelBranscomb
This was fixed in v100.9 (August 2020). The current release is 100.10 (January 2021).
