I have a base layer in which i need to update a selection of parcels with corrected geometries. I have already created the layer containing the correct geometries. (about 1000+ records). In ArcPro, using replace geometry prompts you to select the parcel in question requiring changes, then to digitize the correct points. Rather than digitizing, i want to simply select the correct polygon, ie. 2-steps, select original, select correct, update geometry. Seems this command does not allow this? Any better method ? (rubber sheeting, geometry adjustments, etc?)
