Survey123 repeats not populated upon retrieval
355
06-22-2020 01:40 PM
E_-_MarieCook__GISS_
We have a Survey123 form in production for reporting wildfires and other incidents responded to by NJ Forest Fire Service firefighters. There are multiple repeats in the form. The report is completed in phases, so each is retrieved from the Survey123 inbox following original submittal.
At first, we noticed that information submitted in a repeat wasn’t populated in the form when previously submitted reports were retrieved from the Inbox. After some research, we found information about how to allow queries, updates, and new records within repeats using the “bind::esri:parameters” column in the form’s configuration spreadsheet, and updated that field accordingly. The esri:parameters column is populated the same way for each repeat.
esri:parameters configuration for inbox queries, updates, and additions of repeat records
However, users are still experiencing issues pulling these related records back into the form. This issue is occurring inconsistently within the same report (some repeats come back in while some do not), and among reports (specific repeats come back into some reports but not others). Please refer to the images below for examples of successful (Actions Taken) and unsuccessful (Exact Incident Costs) queries of related records upon inbox retrieval. In the case of the Exact Incident Costs example below where the related records did not populate the form for this repeat, other repeats within the same report were populated.
repeat fields successfully populated from inbox retrievalrepeat fields unsuccessfully populated from inbox retrieval
Users are utilizing Samsung Tab S4s and Dell laptops for data collection. To troubleshoot, I confirmed most recent versions of the Survey123 form and Android/Desktop apps are being used. I have also confirmed that the Inbox is being refreshed prior to report retrieval. The issue is causing users to re-enter information recorded in repeats, resulting in many duplicated entries, added maintenance time, and much user frustration.
Thanks in advance for your help!
JamesTedrick
Esri Esteemed Contributor
Apologies for the delay in response.  This is probably best diagnosed through an Esri Support case.  One thing I'll note is that the query keyword does not take 'true' as a value, but the query to use in retrieving the repeat (or just 'query' by itself to use the default 1=1).
No worries, James! Thank you. I will pass this along.
