Can't get IIdentifyDialog2 to work in VB.net
638
06-21-2020 07:18 AM
MatthiasKl
New Contributor III
I want to use the ArcMap Identify-Tool inside a WindowsForm. So I've created a button and added a clickevent:
    Private Sub btnIdentify_Click(sender As Object, e As EventArgs) Handles btnIdentify.Click
        Dim intObjectID As Integer = lstResults.SelectedValue
        Dim pLayer As ILayer2 = pDocument.FocusMap.Layer(0)
        DoIdentify(pLayer, intObjectID)
    End Sub ‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
I've also created a sub procdedure similar to the one in the ArcObjects API Reference for .NET
    Private Sub DoIdentify(ByVal pLayer As ILayer, ByVal intObjectID As Integer)
        If pActiveView Is Nothing Or pLayer Is Nothing Or intObjectID <= 0 Then
            Return
        End If
        Dim pMap As IMap = pActiveView.FocusMap
        Dim pIdentifyDialog As IIdentifyDialog = New IdentifyDialogClass()
        pIdentifyDialog.Map = pMap
        pIdentifyDialog.ClearLayers()
        Dim pScreenDisplay As IScreenDisplay = pActiveView.ScreenDisplay
        Dim pDisplay As IDisplay = pScreenDisplay
        pIdentifyDialog.Display = pDisplay
        pIdentifyDialog.AddLayerIdentifyOID(pLayer, intObjectID)
        pIdentifyDialog.Show()
    End Sub ‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
This code works perfectly fine. But I really want to use the new IIdentifyDialog2 Interface. But if I change the code to
            Return
        End If
        Dim pMap As IBasicMap2 = pActiveView.FocusMap
        Dim pIdentifyDialog As IIdentifyDialog2 = New IdentifyDialogClass()
        pIdentifyDialog.BasicMap = pMap
        Dim pScreenDisplay As IScreenDisplay3 = pActiveView.ScreenDisplay
I get a NullReferenceException at pIdentifyDialog.ClearLayers() I already tried so many things but somehow I can't get it to work with the new Identify-Tool. Does anyone know the answer?
GKmieliauskas
Hi Matthias,
IIdentifyDialog2 works with tables, when IIdentifyDialog works with layers.
https://desktop.arcgis.com/en/arcobjects/latest/net/webframe.htm#CartoUI_library.htm
MatthiasKl
New Contributor III
Okay, so I only have to use AddTableIdentifyOID instead of AddLayerIdentifyOID and pass a ITable instead of a ILayer? Do I still need ClearLayers? I'm sorry but I am somehow lost. Could you give me a hint what I exactly need to change in my code?
GKmieliauskas
I have found one sample, you can follow it and check if it works:
https://forum.esri-cis.ru/index.php?qa=36329&qa_1=identify
Site in Russian language, but code in VB
At first work with IIdentifyDialog variable (until ClearLayers).
After cast it to IIdentifyDialog2 variable and try your workflow
