AnsweredAssumed Answered
Pro Reviewer Rules in a Map - change database edit version
Question asked by ssalas@blm.gov_BLM_EGIS on Jun 19, 2020
Latest reply on Jul 2, 2020 by ssalas@blm.gov_BLM_EGIS
I am attempting to replicate a method we used with Data Reviewer in ArcMap where we developed a Data Reviewer batch file (RBJ), and would then use that file to perform quality control against each editor's SDE/Enterprise geodatabase version prior to reconcile & post of the version.  I realize RBJs can be run in Pro, but they don't appear to have a long-term future Will ArcGIS Pro support creating Data Reviewer batch jobs in the future?
I attempted to develop some ArcGIS Pro (2.5.1) Reviewer rules (against the SDE.Default version) saved in the map, then I saved the map (Share -> Save As Map File) to disk.  In the editor's ArcGIS Pro session, they import the map file (.mapx) from disk.  In this imported map, they change to their edit version and create the reviewer session in a FGDB, run the reviewer rules from the Manage Quality tab... and it appears to run against the SDE.Default version.  It did not associate their layers with those created in the reviewer rules.
I know in our ArcMap solution, I think there is something in our ArcObjects code that might handle this change of version/workspace (I didn't program that solution).
I'm curious if I'm even on the right path trying to use reviewer rules in this way...?  Or does there need to be some custom code written to achieve this with reviewer rules stored in a map?
Thanks for any ideas,
-S.
Outcomes
