Issues creating a checklist in a feature report template, question type is the issue, is there a workaround?
283
06-17-2020 04:59 PM
MichaelShoemaker
My survey is set up with multiple pages within a repeat, one for each kind of point. This creates a lot of mostly empty fields, as I would discover. The pages often repeat the same questions but with some slight twists - different choices for the same question.
In an attempt to whittle down the empty space, I have set the bindtype option to null in all the pages except a new one, in which I use nested concat functions to find the answer for questions that are repeated across the pages. The problem is, when I make a feature report template and set up for a checklist of values (passing the concatenated field in), it seems that the fact that I am treating the concatenated field as a select_one is unacceptable. It is hidden, so I turned it into a select_one type question, making a list of all the possible choices, and that still didn't work.
In other words, I am not able to make a checkbox using a field that collects the only non-null answer among 4 multiple choice lists. (I use the correct names of the choice values, too).
My report is intended to mimic an existing paper form, so having my checklists work would be a big deal for me!
Thanks for your help!
JamesTedrick
Esri Esteemed Contributor
HI Michael,
Apologies for the delay in response.  Form your description, it sounds like you have multiple sections that each essentially represent a different view of a multiple choice question with a large number of values, is that correct?
One way to work around this would be to have a separate form that you use to view the results where the end question that holds the choices is a multiple choice question instead of a calculation/text.
