Access Survey stored on portal from Hub Intiative
256
06-17-2020 11:38 AM
AlecColarusso
When I attempt to access a survey stored in a portal through arcgis online. I am unable to access the survey when signed into any account, but when I’m signed out (pictured below) the survey is accessible. When I click on the link it prompts me to sign into the Enterprise portal. Is there a way to configure the survey on the portal so people will be able to take the survey while being signed into arcgis online?
Thank you for your time!
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Alec,
Apologies for the delay in response.  It looks like this is the same as https://community.esri.com/thread/255050-has-anybody-attempted-to-host-surveys-on-the-hub-and-have-r... , correct?
