Writing a table to memory in ArcPy?
5828
5
06-17-2020 02:52 AM
Elbertde_Hon
Currently I try to improve an ArcPy script which is runned outside ArcGIS Pro 2.5 in Spyder.
I want to write a table to memory using the Table to Table tool. This tool is placed inside a loop and writes a new table to my workspace for every run.
Part of my code:
#Defining output path
output = "Routebestand_portaal_"+str(nummer_portaal)+"_selectie"
portalen_join_met_totaal = arcpy.AddJoin_management(in_layer_or_view="Routebestand_200605_totaalbestand_opgeschoond_copy",
                                                    in_field="Portal_OBJECTID", join_table=Portaal_vultabel,
                                                    join_field="Portal_OBJECTID", join_type="KEEP_COMMON")[0]
Portaal_vultabel = r"C:\Users\Work\Portalen_met_intensiteit"
#Write table to gdb
arcpy.TableToTable_conversion(in_rows=portalen_join_met_totaal, out_name= output, where_clause="", field_mapping="Van___naar \"Van___naar\" true true false 200 Text 0 0,First,#,C:\\Users\\Work\\Data.gdb\\Routebestand_200605_totaalbestand_opgeschoond_copy,Routebestand_200605_totaalbestand_opgeschoond_copy.Van___naar,0,200;VTGKM_VWH \"VTGKM_VWH\" true true false 8 Double 0 0,First,#,C:\\Users\\Work\\Data.gdb\\Routebestand_200605_totaalbestand_opgeschoond_copy,Routebestand_200605_totaalbestand_opgeschoond_copy.VTGKM_VWH,-1,-1;Portal_OBJECTID \"Portal_OBJECTID\" true true false 4 Long 0 0,First,#,C:\\Users\\Work\\Data.gdb\\Routebestand_200605_totaalbestand_opgeschoond_copy,Routebestand_200605_totaalbestand_opgeschoond_copy.Portal_OBJECTID,-1,-1;SUM_VTGKM_TOT \"SUM_VTGKM_TOT\" true true false 8 Double 0 0,First,#,C:\\Users\\Work\\Data.gdb\\Routebestand_200605_totaalbestand_opgeschoond_copy,Portalen_met_intensiteit.SUM_VTGKM_TOT,-1,-1;SUM_VTGKM_VWH \"SUM_VTGKM_VWH\" true true false 8 Double 0 0,First,#,C:\\Users\\Work\\Data.gdb\\Routebestand_200605_totaalbestand_opgeschoond_copy,Portalen_met_intensiteit.SUM_VTGKM_VWH,-1,-1", config_keyword="")[0]‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
..this code works and writes the table to my workspace. Now I want to write the table to memory.
My first approach was figure out how to write a table to memory outside a loop and without considering the variable output.
#Approach1  - using 'memory'
output1 = r"memory\tmpTable"
arcpy.TableToTable_conversion(in_rows=portalen_join_met_totaal, out_name= output1, where_clause="", field_mapping="Van___naar \"Van___naar\" true true false 200 Text 0 0,First,#,C:\\Users\\Work\\Data.gdb\\Routebestand_200605_totaalbestand_opgeschoond_copy,Routebestand_200605_totaalbestand_opgeschoond_copy.Van___naar,0,200;VTGKM_VWH \"VTGKM_VWH\" true true false 8 Double 0 0,First,#,C:\\Users\\Work\\Data.gdb\\Routebestand_200605_totaalbestand_opgeschoond_copy,Routebestand_200605_totaalbestand_opgeschoond_copy.VTGKM_VWH,-1,-1;Portal_OBJECTID \"Portal_OBJECTID\" true true false 4 Long 0 0,First,#,C:\\Users\\Work\\Data.gdb\\Routebestand_200605_totaalbestand_opgeschoond_copy,Routebestand_200605_totaalbestand_opgeschoond_copy.Portal_OBJECTID,-1,-1;SUM_VTGKM_TOT \"SUM_VTGKM_TOT\" true true false 8 Double 0 0,First,#,C:\\Users\\Work\\Data.gdb\\Routebestand_200605_totaalbestand_opgeschoond_copy,Portalen_met_intensiteit.SUM_VTGKM_TOT,-1,-1;SUM_VTGKM_VWH \"SUM_VTGKM_VWH\" true true false 8 Double 0 0,First,#,C:\\Users\\Work\\Data.gdb\\Routebestand_200605_totaalbestand_opgeschoond_copy,Portalen_met_intensiteit.SUM_VTGKM_VWH,-1,-1", config_keyword="")[0]
..or these lines:
#Approach2 - using 'in_memory'
output2 = r"in_memory\tmpTable"
arcpy.TableToTable_conversion(in_rows=portalen_join_met_totaal, out_name= output2, where_clause="", field_mapping="Van___naar \"Van___naar\" true true false 200 Text 0 0,First,#,C:\\Users\\Work\\Data.gdb\\Routebestand_200605_totaalbestand_opgeschoond_copy,Routebestand_200605_totaalbestand_opgeschoond_copy.Van___naar,0,200;VTGKM_VWH \"VTGKM_VWH\" true true false 8 Double 0 0,First,#,C:\\Users\\Work\\Data.gdb\\Routebestand_200605_totaalbestand_opgeschoond_copy,Routebestand_200605_totaalbestand_opgeschoond_copy.VTGKM_VWH,-1,-1;Portal_OBJECTID \"Portal_OBJECTID\" true true false 4 Long 0 0,First,#,C:\\Users\\Work\\Data.gdb\\Routebestand_200605_totaalbestand_opgeschoond_copy,Routebestand_200605_totaalbestand_opgeschoond_copy.Portal_OBJECTID,-1,-1;SUM_VTGKM_TOT \"SUM_VTGKM_TOT\" true true false 8 Double 0 0,First,#,C:\\Users\\Work\\Data.gdb\\Routebestand_200605_totaalbestand_opgeschoond_copy,Portalen_met_intensiteit.SUM_VTGKM_TOT,-1,-1;SUM_VTGKM_VWH \"SUM_VTGKM_VWH\" true true false 8 Double 0 0,First,#,C:\\Users\\Work\\Data.gdb\\Routebestand_200605_totaalbestand_opgeschoond_copy,Portalen_met_intensiteit.SUM_VTGKM_VWH,-1,-1", config_keyword="")[0]
..both these options delivered an error message:
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000354: The name contains invalid characters
Failed to execute (TableToTable).
What I would like to get is something like r"memory\   + "Routebestand_portaal_"+str(nummer_portaal)+"_selectie"
Any suggestions how to solve this?
DavidPike
MVP Notable Contributor
TableToTable(in_rows, out_path, out_name, {where_clause}, {field_mapping}, {config_keyword})
out_path = "in_memory"
out_name = "Routebestand_portaal_" + str(nummer_portaal) + "_selectie"
maybe
DavidPike
import os
os.path.join("in_memory","Routebestand_portaal_"+str(nummer_portaal)+"_selectie")
Elbertde_Hon
Thanks David for your reply! I tried to implement your suggestion in the following way:
import os
output1=os.path.join("in_memory","Routebestand_portaal_"+str(nummer_portaal)+"_selectie")
However, I still got the same error. Probably this tool just expects a table name (in relation to the set workspace) and not a whole path..
DavidPike
maybe
Elbertde_Hon
That works perfectly David!
JoshuaBixby
MVP Esteemed Contributor
in_memory represents the older in-memory workspace, for Pro I recommend transitioning to memory.
Since the error states invalid characters, can you paste one of the full paths (not the code to make the path) here for people to see?
