LocalServer 100.8 Contour GPServer sample startup fails
662
06-15-2020 08:20 AM
by Anonymous User
Not applicable
Is anyone able to turn on logging, or get the Contouring sample gp service to work?
Local Server Utility shows Enable Logging is checked.
However, when I click Start Local Server on the sample here, VS shows "Logging disabled" in the output window:
Licensed For Developer Use Only
'apppid' = '26784'
'cleanuponshutdown' = ''
'enablehtmlviews' = ''
datadir does not exist, creating: "C:\EsriSamples\Temp\arcgisruntime_8928"
DataDir : "C:\EsriSamples\Temp\arcgisruntime_8928"
Message : Logging disabled
AppDataLocalDir : "C:\ESRISA~1\AppData\Local"
AppDataRoamingDir : "C:\ESRISA~1\AppData\Roaming"
AppDataCommonDir : "C:\ESRISA~1\AppData\Common"
MyDocumentsDir : "C:\ESRISA~1\AppData\Documents"
CrashDumpPath : "C:\EsriSamples\Temp\ArcGISRuntimeErrorReports"
The Map Service and Feature Service work as expected, however the GP service presents this:
The C:\EsriSamples\Temp\arcgisruntime_8928\contour folder exists, but has no files.
There are no log files. Attached is dmp file.
Same result when running as admin.
MichaelBranscomb
Esri Frequent Contributor
Hi Kirk,
When did you grab the repo? A fix was merged to the samples on June 12 via Local Server 100.8 by ZackAllen · Pull Request #802 · Esri/arcgis-runtime-samples-dotnet · GitHub .
Mike
MichaelBranscomb
Hi Kirk,
Mike
