Unable to Trace in Water Utility network
498
06-14-2020 04:13 AM
vinodkumarborkar
I have migrated data from Geometric network to Utility network for water Utility , after migration I work on Topology and remove all dirty areas , Then I am trying to run any traces ,I am getting error "ERROR 001797: No subnetwork controller was discovered." I have imported same schema from Esri Sample Water Utility network foundation template.
My concern is how to get Value attribute in Subnetwork controller field in which I am Unable to edit manually I think this should update automatically,I have updated Unique  Subcontroller name manually using Modify subnetwork controller pane. for Storage and Meter Asset group.
After than run update Subnetwork controller tools.
So please suggest me how to update Subnetwork attribute in field to working with Traces.
Attached Water device attribute field screenshot.
Tags (1)
MikeMillerGIS
Esri Frequent Contributor
Yes, you will need to use Modify Subnetwork Controller to assign a controller to that tier.  Make sure to assign a controller at the system tier.
