Request Print Map(Export Web Map) rest API exception
644
06-13-2020 02:31 AM
SailiasPeng
When Call Export Web Map Task—ArcGIS REST API: Services Directory | ArcGIS for Developers  with Client Side graphics (ExportWebMap specification—ArcGIS REST API: Services Directory | ArcGIS for Developers ),
The parameters:
Web_Map_as_Json:  Web_map_as_json.json
Format: PNG8
Return Format: JSON
Request Method: Post
the service sometimes return Gateway timeout error, and return an empty image(as 2kb size) most of the time. I checked the info/log on the server,but there is not any exception or error output.
Also, the I've tested on these services:
http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%2...
http://sampleserver5.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%2...
it returns images normally, but sometimes empty images unpredictably either.
Does any one encounter with this?
VictorTey
Hi, just taking a shot in the air, are your request going through a proxy gateway or reverse proxy, I have seem implementation of proxies behaving like that.
