Upgrading .NET UWP SDK from 1.0.4 to 1.0.8 in x64 deployment
685
06-11-2020 12:44 PM
HélioFuques
I have a sample code running in version 1.0.4 and when I upgraded it to the version 1.0.8 it crash with an error when loading the runtimecorenet.dll.
When I run the code, it returns a xaml parser error.
The strange is that it works in x86 deployment.
dotMorten_esri
Esri Notable Contributor
Could you try and close Visual Studio, delete the obj and bin folders, and try again?
HélioFuques
Yes. But the problem persists.
dotMorten_esri
Try browsing the \bin\ folder down to where the appx folder was generated. Do you see a file next to Esri.ArcGISRuntime.dll that's called "RuntimeCoreNet.dll" ?
Does this only happen for x64 and not x86?
