CreateReplica for a FeatureService on ArcGIS Online return nothing
400
06-12-2020 10:56 AM
marceloctorres
We are developing a Xamarin.Forms app that uses ArcGIS Runtime SDK for .NET to do offline editing.  To accomplish this task, a feature service was published to ArcGIS Online. Until the end of April the application downloaded the replicas without problem, but from that time the application gets stuck at 45% of the process (data reported by the SDK) and it is necessary to interrupt the download of the replica.
Reviewing, the download directory shows that the basemap is downloaded in .tpk or .vtpk format but the gdb with the feature service data does not. By doing a web-debugging it was possible to set that the SDK calls the createReplica function of the Rest Api, with the following parameters:
f
json
async
true
attachmentsSyncDirection
bidirectional
dataFormat
sqlite
geometry
{"xmin":-74.051215294838002,"ymin":4.6563683424734599,"xmax":-74.032975009746195,"ymax":4.6644197585674796}
geometryType
esriGeometryEnvelope
inSR
{"wkid":4326}
layerQueries
{"1":{"queryOption":"useFilter","useGeometry":true},"0":{"queryOption":"useFilter","useGeometry":true},"2":{"includeRelated":true,"queryOption":"none"},"3":{"includeRelated":true,"queryOption":"none"},"4":{"includeRelated":true,"queryOption":"none"},"5":{"includeRelated":true,"queryOption":"none"},"6":{"includeRelated":true,"queryOption":"none"},"7":{"includeRelated":true,"queryOption":"none"},"8":{"queryOption":"all"}}
layers
[1,0,2,3,4,5,6,7,8]
replicaOptions
{ "syncDataOptions": 1 }
replicaSR
{"wkid":102100,"latestWkid":3857}
returnAttachments
true
syncModel
perLayer
transportType
esriTransportTypeUrl
These are the HTTP request and response messages in raw format:
POST https://services1.arcgis.com/7S16A7PAFcmSmqJA/arcgis/rest/services/InspeccionPublica_WFL1/FeatureSer...
Referer: http://31e6402e-0407-4419-a6c3-7c6d18576017mm77914cpbf52/
Accept-Encoding: gzip, deflate
User-Agent: ArcGISRuntime-NET/100.8 (Windows 10.0.17763; Win64; WOW64; UAP; Windows.Desktop) 31e6402e-0407-4419-a6c3-7c6d18576017/1.0.0
Content-Length: 1225
Content-Type: application/x-www-form-urlencoded
Host: services1.arcgis.com
Connection: Keep-Alive
Cache-Control: no-cache
f=json&async=true&attachmentsSyncDirection=bidirectional&dataFormat=sqlite&geometry=%7B%22xmin%22%3A-74.051215294838002%2C%22ymin%22%3A4.6563683424734599%2C%22xmax%22%3A-74.032975009746195%2C%22ymax%22%3A4.6644197585674796%7D&geometryType=esriGeometryEnvelope&inSR=%7B%22wkid%22%3A4326%7D&layerQueries=%7B%221%22%3A%7B%22queryOption%22%3A%22useFilter%22%2C%22useGeometry%22%3Atrue%7D%2C%220%22%3A%7B%22queryOption%22%3A%22useFilter%22%2C%22useGeometry%22%3Atrue%7D%2C%222%22%3A%7B%22includeRelated%22%3Atrue%2C%22queryOption%22%3A%22none%22%7D%2C%223%22%3A%7B%22includeRelated%22%3Atrue%2C%22queryOption%22%3A%22none%22%7D%2C%224%22%3A%7B%22includeRelated%22%3Atrue%2C%22queryOption%22%3A%22none%22%7D%2C%225%22%3A%7B%22includeRelated%22%3Atrue%2C%22queryOption%22%3A%22none%22%7D%2C%226%22%3A%7B%22includeRelated%22%3Atrue%2C%22queryOption%22%3A%22none%22%7D%2C%227%22%3A%7B%22includeRelated%22%3Atrue%2C%22queryOption%22%3A%22none%22%7D%2C%228%22%3A%7B%22queryOption%22%3A%22all%22%7D%7D&layers=%5B1%2C0%2C2%2C3%2C4%2C5%2C6%2C7%2C8%5D&replicaOptions=%7B+%22syncDataOptions%22%3A+1+%7D&replicaSR=%7B%22wkid%22%3A102100%2C%22latestWkid%22%3A3857%7D&returnAttachments=true&syncModel=perLayer&transportType=esriTransportTypeUrl
HTTP/1.1 200 OK
Content-Type: text/plain; charset=utf-8
Content-Length: 161
Connection: keep-alive
Cache-Control: private, max-age=0, s-maxage=0
Server: Microsoft-IIS/10.0
X-ArcGIS-Correlation-Id: |a597c0a11d730b469748f272a747dc95.52de414d_
X-ArcGIS-Instance: MTSDS_Web_IN_20
X-Powered-By: ASP.NET
Access-Control-Allow-Origin: *
Date: Sun, 07 Jun 2020 07:03:15 GMT
X-Cache: Miss from cloudfront
Via: 1.1 8e7a7fa539063c32ccfe07b305af2b26.cloudfront.net (CloudFront)
X-Amz-Cf-Pop: BOG50-C1
X-Amz-Cf-Id: nd6Ocot4KGMAOB_Yzc4DP-ll8BHsq3WpfdKV97baXm3dAFv27ndnQQ==
{"statusUrl":"https://services1.arcgis.com/7S16A7PAFcmSmqJA/arcgis/rest/services/InspeccionPublica_WFL1/FeatureSer..."}
The response in json format contains the url of the job that allow :  1) Monitor the progress and 2) Download the result. However, when checking the status of the replica over and over the body response is the same: Never finish and never shows result url:
Replica is created with the following data:
{   "replicaName" : "MyReplica_2726",   "replicaID" : "6b2ee0ce-739d-48fe-82e4-bfa576f19fba",   "replicaOwner" : "mctorres",   "targetType" : "client",   "layerServerGens" : [     {       "id" : 1,       "serverGen" : 826592     },     {       "id" : 0,       "serverGen" : 826592     },     {       "id" : 2,       "serverGen" : 826592     },     {       "id" : 3,       "serverGen" : 826592     },     {       "id" : 4,       "serverGen" : 826592     },     {       "id" : 5,       "serverGen" : 826592     },     {       "id" : 6,       "serverGen" : 826592     },     {       "id" : 7,       "serverGen" : 826592     },     {       "id" : 8,       "serverGen" : 826592     }   ],   "creationDate" : 1591513396000,   "lastSyncDate" : 1591513396000,   "syncModel" : "perLayer",   "returnAttachments" : false,   "spatialRel" : "Intersects",   "geometry" : {     "xmin" : -74.051215294838,     "ymin" : 4.65636834247346,     "xmax" : -74.0329750097462,     "ymax" : 4.66441975856748,     "spatialReference" : {       "wkid" : 4326,       "latestWkid" : 4326     }   },     "layers" : [     {       "id" : 1,       "queryOption" : "useFilter",       "useGeometry" : true,       "includeRelated" : true,       "where" : ""     },     {       "id" : 0,       "queryOption" : "useFilter",       "useGeometry" : true,       "includeRelated" : true,       "where" : ""     },     {       "id" : 2,       "queryOption" : "none",       "useGeometry" : false,       "includeRelated" : true,       "where" : ""     },     {       "id" : 3,       "queryOption" : "none",       "useGeometry" : false,       "includeRelated" : true,       "where" : ""     },     {       "id" : 4,       "queryOption" : "none",       "useGeometry" : false,       "includeRelated" : true,       "where" : ""     },     {       "id" : 5,       "queryOption" : "none",       "useGeometry" : false,       "includeRelated" : true,       "where" : ""     },     {       "id" : 6,       "queryOption" : "none",       "useGeometry" : false,       "includeRelated" : true,       "where" : ""     },     {       "id" : 7,       "queryOption" : "none",       "useGeometry" : false,       "includeRelated" : true,       "where" : ""     },     {       "id" : 8,       "queryOption" : "all",       "useGeometry" : false,       "includeRelated" : true,       "where" : ""     }   ],   "spatialReference" : {     "wkid" : 102100,     "latestWkid" : 3857   } }
The data source for feature service publishing is a filegdb that has two layers and seven tables with relationships. These are the service data:
   "currentVersion" : 10.7,
   "serviceItemId" : "c93d8a2eb66049f789a8014cfb35c090",
   "serviceDescription" : "InspeccionPublica",
   "hasVersionedData" : false,
   "supportsDisconnectedEditing" : false,
   "hasStaticData" : false,
   "hasSharedDomains" : false,
   "maxRecordCount" : 2000,
   "supportedQueryFormats" : "JSON",
   "supportsVCSProjection" : false,
   "capabilities" : "Create,Delete,Query,Update,Editing,Sync",
   "description" : "",
   "copyrightText" : "",
     "wkid" : 102100,
     "latestWkid" : 3857
   "initialExtent" : {
     "xmin" : -8243343.5792444451,
     "ymin" : 518916.07693824446,
     "xmax" : -8241313.079996096,
     "ymax" : 519815.3295977416,
       "wkid" : 102100,
       "latestWkid" : 3857
   "fullExtent" : {
     "xmin" : -8242629.4319193121,
     "ymin" : 519098.313887921,
     "xmax" : -8242083.9664079556,
     "ymax" : 519623.25095530582,
       "wkid" : 102100,
       "latestWkid" : 3857
   "allowGeometryUpdates" : true,
   "units" : "esriMeters",
   "supportsAppend" : true,
   "supportsSharedDomains" : true,
   "size" : 540672,
   "syncEnabled" : true,
   "syncCapabilities" : {
     "supportsAsync" : true,
     "supportsRegisteringExistingData" : true,
     "supportsSyncDirectionControl" : true,
     "supportsPerLayerSync" : true,
     "supportsPerReplicaSync" : true,
     "supportsSyncModelNone" : true,
     "supportsRollbackOnFailure" : true,
     "supportsAttachmentsSyncDirection" : true
   "supportsApplyEditsWithGlobalIds" : true,
   "supportsReturnDeleteResults" : true,
   "editorTrackingInfo" : {
     "enableEditorTracking" : false,
     "enableOwnershipAccessControl" : false,
     "allowOthersToQuery" : true,
     "allowOthersToUpdate" : true,
     "allowOthersToDelete" : false,
     "allowAnonymousToQuery" : true,
     "allowAnonymousToUpdate" : true,
     "allowAnonymousToDelete" : true
   "xssPreventionInfo" : {
     "xssPreventionEnabled" : true,
     "xssPreventionRule" : "InputOnly",
     "xssInputRule" : "rejectInvalid"
   "layers" : [
       "id" : 0,
       "name" : "Lindero",
       "parentLayerId" : -1,
       "defaultVisibility" : true,
       "subLayerIds" : null,
       "minScale" : 0,
       "maxScale" : 0,
       "geometryType" : "esriGeometryPolyline"
       "id" : 1,
       "name" : "Predio",
       "minScale" : 0,
       "maxScale" : 0,
       "geometryType" : "esriGeometryPolygon"
   "tables" : [
       "id" : 2,
       "name" : "Derecho",
       "minScale" : 0,
       "maxScale" : 0
       "id" : 3,
       "name" : "Anexo del Derecho",
       "minScale" : 0,
       "maxScale" : 0
       "id" : 4,
       "name" : "Interesado",
       "minScale" : 0,
       "maxScale" : 0
       "id" : 5,
       "name" : "Anexo del Interesado",
       "minScale" : 0,
       "maxScale" : 0
       "id" : 6,
       "name" : "Aprobación",
       "minScale" : 0,
       "maxScale" : 0
       "id" : 7,
       "name" : "Aprobación Lindero",
       "minScale" : 0,
       "maxScale" : 0
       "id" : 8,
       "name" : "Predio Lindero",
       "minScale" : 0,
       "maxScale" : 0
Marcelo César Torres
