mpc
Migrating VB script for Arc10
Discussion created by mpc on Mar 31, 2011
Latest reply on Apr 28, 2011 by mpc
I didn't actually write this script and I'm far more familiar with Python and haven't done any VB. In Python the equivalent outcome takes far too long, so I need to implement this instead as time is of the essence.
The error I get using Field Calculator is "Expected end of statement". Any ideas on what's wrong? I gather in Arc10 'Dim count as Long' gets changed to 'Dim count'. Aside from that my knowledge is lacking :(
Thanks in advance!
'** Declare variable to store population sum in
Dim count As Long
'** Get pointer variables to current arcmap project
Dim pMxDoc As IMxDocument
Dim pMap As IMap
Set pMxDoc = ThisDocument
Set pMap = pMxDoc.FocusMap
'** Get pointer variable to the polygon layer for which you wish
'** to count the # of intersects from
Dim pCountLayer As IFeatureLayer
'SET THIS...At the moment the "CountLayer"
'must be FIRST in ArcMap TOC
Set pCountLayer = pMap.Layer(0)
'** Set up a spatial filter and feature cursor to select
'** all polygons that interest the current layer's midpoint
'** and iterate through results to produce a count
Dim pSpatialFilter As ISpatialFilter
Dim pFCursor As IFeatureCursor
Dim pFeature As IFeature
Dim pPolygon As IPolygon
Dim pMidPoint as IPoint
Dim pArea as IArea
Set pArea = [Shape]
Set pMidPoint = pArea.labelpoint
Set pSpatialFilter = New SpatialFilter
Set pSpatialFilter.Geometry = pmidpoint
pSpatialFilter.SpatialRel = esriSpatialRelIntersects
Set pFCursor = pCountLayer.Search(pSpatialFilter, True)
Set pFeature = pFCursor.NextFeature
'** iterate through selected polygons to count for each
'** polygon to be analyzed
Count = 0
Do Until pFeature Is Nothing
  Count = Count + 1
Loop
Outcomes
