How to show popup for WMS layer in JS API 4.15?
2866
7
06-04-2020 01:12 AM
SpikyMS
Hi everyone,
I am trying to show a popup for a WMSLayer. I have build a sample here, but no popup is opened when clicking in the map: https://codepen.io/dpayk/pen/gOPbOxJ?editors=1000
What do I have to do to show a popup?
Thanks a lot
Dennis
SpikyMS
Just in case someone is looking for a working sample, here it is (I also updated the codepen linked above):
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
    <title>Popup for WMS - 4.15</title>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.15/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.15/"></script>
    <script>
      require([
        "esri/Map",
        "esri/layers/WMSLayer",
        "esri/views/MapView"
      ], function(Map, WMSLayer, MapView) {
        var map = new Map({
          basemap: "gray"
        var view = new MapView({
          container: "viewDiv",
          map: map,
          center: [7, 51.5],
          zoom: 9
        var layer = new WMSLayer({
          url: "https://www.wms.nrw.de/wms/krankenhaus",
          featureInfoFormat: "text/html",
          featureInfoUrl: "https://www.wms.nrw.de/wms/krankenhaus?",
          sublayers: [
              popupEnabled: true,
              queryable: true
        map.add(layer);
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
  </body>
</html>
ChristianBischof
<html>
  <head>
    <meta
      name="viewport"
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <link
      rel="stylesheet"
    <script>
      var view;
      require([
        "esri/Map",
        "esri/views/MapView",
      ], function (Map, WMSLayer, MapView) {
        var map = new Map({
          basemap: "gray",
          map: map,
          center: [7, 51.5],
          zoom: 9,
          sublayers: [
              popupEnabled: true,
        map.add(layer);
        view.when(function () {
          view.popup.autoOpenEnabled = false;
          view.on("click", function (event) {
              var info = layer.getFeatureInfo();
              console.log(info)
            view.popup.open({
    </script>
  </head>
  <body>
  </body>
</html>
Add the lines which add the click event handler (form line 59) to your code. The popup should open at the click event's location
SpikyMS
thanks for your response. Unfortunately it does not work. The method getFeatureInfo does not exist in the 4.x API.
I would be thankful for a working sample 🙂
Dennis
elvispz
The function is not executed, please Helpme, Tengo un wms y no puedo ver la info
wms---> https://idec.ineter.gob.ni/geoserver/geonode/wms/capacartografiacatastral_idec
Here web in geonode and geoserver https://idec.ineter.gob.ni/catalogue/#/dataset/5
elvispz
<html>
  <head>
    <meta
      name="viewport"
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <link
      rel="stylesheet"
    <script>
      var view;
      require([
        "esri/Map",
        var map = new Map({
          basemap: "gray",
          map: map,
          center: [-86.266, 12.129],
          zoom: 16,
            sublayers: [
              popupEnabled: true,
  queryable: true
        map.add(layer);
              console.log(info)
            view.popup.open({
    </script>
  </head>
  <body>
  </body>
</html>
SpikyMS
<html>
  <head>
    <meta
      name="viewport"
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <link
      rel="stylesheet"
    <script>
      require([
        "esri/Map",
        var map = new Map({
          basemap: "gray"
          map: map,
          center: [7, 51.5],
          zoom: 9
          sublayers: [
              popupEnabled: true,
              queryable: true
        map.add(layer);
    </script>
  </head>
  <body>
  </body>
</html>
AgrimotionTeam
Hi Dennis
After hours of searching I came across your post. THANK YOU!! this helped immensely.
I am however receiving a x-frame issue now, any chance you have some advise please? 🙂
Refused to display 'url' in a frame because it set 'X-Frame-Options' to 'sameorigin'.
TIA
Hugo
imritanshu
New Contributor III
were you able to resolve this?
