FeatureLayer geometry type?
526
06-02-2020 02:39 PM
MikeQuetel1
I'm programmatically adding a bunch of feature layers to a map from a local, runtime geodatabase.  Prior to adding to the map, I would like to get the geometry type of the feature table (or feature layer).  Can someone assist me with the most efficient way to get that info?  I'm pretty new to QML.
Thanks in advance!
Mike
LucasDanzinger
Esri Frequent Contributor
You could do something like this:
// create the geodatabase
Geodatabase {
    path: dataPath + "geodatabase/LA_Trails.geodatabase"
    Component.onCompleted: load();
    onLoadStatusChanged: {
        if (loadStatus === Enums.LoadStatusLoaded) {
            console.log("Geodatabase loaded");
            for (var i = 0; i < geodatabaseFeatureTables.length; i++) {
                const ft = geodatabaseFeatureTables[i];
                ft.loadStatusChanged.connect(()=>{
                                                 if (ft.loadStatus === Enums.LoadStatusLoaded) {
                                                     if (ft.geometryType === Enums.GeometryTypePoint) {
                                                         console.log("this is a point")
                                                     } else if (ft.geometryType === Enums.GeometryTypePolygon) {
                                                         console.log("this is a polygon")
                                                     } else if (ft.geometryType === Enums.GeometryTypePolyline) {
                                                         console.log("this is a polyline")
                ft.load();
LucasDanzinger
Geodatabase {
                ft.load();
