Just wondering if anyone knows of a way to code some conditional symbology within ArcPro using Arcade? I need one feature class to not display any symbology IF a field value in the other feature class contains a certain value. Thanks!
Unfortunately, in the symbology profile it is not possible to access values from another featureclass. You can only access the attributes of the current feature to define the symbology.
In case this a a static condition, you could perhaps create a field and use the field calculation to perform the validation and use that field for symbology. Can you explain a little more about your use case? Why does a value in another featureclass define the visibility of a layer? Is this only in the current view window or does this apply to the entire featureclass?
