Issues publishing a scene from large LAS file
1432
10
06-02-2020 08:38 AM
ToddEason
I have published a scene layer from an LAS file that contains approx 100 million points. I have previously done this with smaller datasets but with this one I am having some major rendering issues of the points. Parts of the scene render correctly and never have an issue, other areas are bad 100% of the time, and some areas are just completely random. I have tried multiple settings with the display limits and density and seem to have the same result. I have no issues viewing the LAS in ArcGIS Pro. Any advice would be appreciated. I have attached some images showing the issues.
RussRoberts
Esri Notable Contributor
Can you share the layer and I can take a look?
Thanks!
ToddEason
Russell Roberts‌ - I'm trying to find you on AGOL and it doesn't seem to. Any suggestions on just adding you to a group so you can see it? I don't have the option to just make it public.
RussRoberts
You can invite russell_jsapi into a group.
RussRoberts
Also what version of Pro did you use to create this SLPK?
Thanks!
Russ
ToddEason
2.5.1
RussRoberts
If possible can you share the las file used to create this dataset to the group as a zipped file?
Thanks!
ToddEason
I have added the dataset as a zip and shared.
ToddEason
Russell Roberts‌ - Any updates?
Thanks!
Todd
RussRoberts
Not yet, looking into the LAS data and the SLPK cooker right now if there is an issue there.
Thanks!
Russ
