Graphics for on Map click
6703
8
06-02-2020 04:29 AM
MatildaOtiede
Hi All,
Need help to achieve the following
What works at the moment, you click on a map and it returns the coordinates of that location
You do a search and it returns a popup info.
I would like to click on the map using a graphic point
Also when the search result is on the map, I want the graphic point to be used.
I have the graphic symbol  in the code, not sure how to  use it on the locator and evt.mapPoint.
Thanks in advance
function(Map, MapView, Search, Graphic, FeatureLayer) {
var map = new Map({
basemap: "topo"
// Add the layer to the map
//map.add(trailsLayer); // Optionally add layer to map
var view = new MapView({
container: "viewDiv",
map: map,
center: [-0.14718, 51.51161],
zoom: 17
// Search
var search = new Search({
view: view
search.defaultSource.withinViewEnabled = false; // Limit search to visible map area only
view.ui.add(search, "top-right"); // Add to the map
// Add instruction to the map
view.ui.add("instruction", "bottom-left")
// Find address
var simpleMarkerSymbol = {
type: "simple-marker",
color: [226, 119, 40], // orange
outline: {
color: [255, 255, 255], // white
width: 1
var pointGraphic = new Graphic({
geometry: point,
symbol: simpleMarkerSymbol
view.graphics.add(pointGraphic);
function showPopup(address, pt) {
view.popup.open({
title: "Find Address Result",
content: address + "<br><br> Lat: " + Math.round(pt.latitude * 100000)/100000 + " Lon: " + Math.round(pt.longitude * 100000)/100000,
actions: [{
image: "beer.png",
title: "get xy"
view.on("click", function(evt){
search.clear();
view.popup.clear();
var locatorSource = search.defaultSource;
locatorSource.locator.locationToAddress(evt.mapPoint)
.then(function(response) {
var address = response.address.Match_addr;
// Show the address found
showPopup(address, evt.mapPoint);
}, function(err) {
// Show no address found
showPopup("No address found for this location.", evt.mapPoint);
});</script>
Tags (1)
ChristianBischof
Is this what you're looking for?
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
  ArcGIS API for JavaScript, https://js.arcgis.com
  For more information about the intro-graphics sample, read the original sample description at developers.arcgis.com.
  https://developers.arcgis.com/javascript/latest/sample-code/intro-graphics/index.html
    <title>DevLabs - Search and Geocode</title>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.15/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.15/"></script>
    <style>
      html,
      body {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 80%;
        width: 60%;
      #instruction {
        padding: 15px;
        background: white;
        color: black;
        border: 5px solid gold;
        font-family: sans-serif;
        font-size: 1.2em;
      #instruction2 {
        width: 60%;
        margin-top: 4px;
      #getLocBtn {
        float: left;
        margin-top: 4px;
    </style>
    <script>
      require([
        "esri/Map",
        "esri/views/MapView",
        "esri/Graphic",
        "esri/widgets/Search",
        "esri/tasks/Locator",
      ], function (Map, MapView, Graphic, Search, Locator) {
        var map = new Map({
          basemap: "topo",
          map: map,
          zoom: 17,
          view: view,
        //search.defaultSource.withinViewEnabled = false; // Limit search to visible map area only
        view.ui.add("instruction", "bottom-left");
        view.on("click", function (evt) {
          // Create a graphic and add the geometry and symbol to it
          var graphic = new Graphic({
            geometry: {
              type: "point",
              latitude: evt.mapPoint.latitude,
              longitude: evt.mapPoint.longitude,
              spatialReference: view.spatialReference,
            symbol: {
              type: "simple-marker", // autocasts as new SimpleFillSymbol
              color: [255, 10, 10],
              outline: {
                // autocasts as new SimpleLineSymbol()
                width: 2,
          view.graphics.removeAll();
          view.graphics.add(graphic);
          search.search(evt.mapPoint);
          search.resultGraphicEnabled = false;
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
    <div id="instruction">
        Click on the map to retrieve coordinates and address
      </div>
  </body>
</html>
ChristianBischof
view.on("click", function (event) {
            view.popup
              .fetchFeatures(event.screenPoint)
              .then(function (response) {
                  console.log(response);
                // Access the response from fetchFeatures
                response.allGraphicsPromise.then(function (graphics) {
                  // Set the feature widget's graphic to the returned graphic from fetchFeatures
                  console.log(graphics[0]);
            view.popup.open({
This code snippet gets you the data of the features (if there are any) at the event.mapPoint. Sorry I'm not sure if I got your problem right.
With graphics.attributes you can get the information from the feature you clicked on.
MatildaOtiede
Thanks Christian.
See the full code below. Using the search to search for an address, the search result should have a red graphic point and a popup window.
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
<style>
html,
body {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
#viewDiv {
padding: 0;
margin: 0;
height: 80%;
width: 60%;
#instruction {
padding: 15px;
background: white;
color: black;
font-size: 1.2em;
#instruction2 {
width: 60%;
margin-top: 4px;
#getLocBtn {
float: left;
margin-top: 4px;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.3/esri/css/main.css">
<script src="https://js.arcgis.com/4.3/"></script>
<script>
require([
"esri/Map",
"esri/layers/FeatureLayer",
"esri/widgets/Locate",
"esri/Graphic",
"dojo/domReady!"
], function(Map, MapView, Search, Graphic, FeatureLayer, Locate) {
var map = new Map({
basemap: "topo"
map: map,
zoom: 17
// Search
view: view
// Find address
outline: {
width: 1
geometry: point,
view.popup.open({
actions: [{
image: "beer.png",
title: "get xy"
search.clear();
view.popup.clear();
}, function(err) {
view.popup
view.popup.open({
});</script>
</head>
<body>
</div>
</body>
</html>
ChristianBischof
//############ point variable was missing above pointGraphic declaration ###########
var point = {
     type: "point", // autocasts as new Point()
additionally I've commented out my first suggestion because I think you don't need it
Full code:
<!DOCTYPE html>
<html>
  <head>
    <meta
      name="viewport"
    <style>
      html,
      body {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 80%;
        width: 60%;
      #instruction {
        padding: 15px;
        background: white;
        color: black;
        font-size: 1.2em;
      #instruction2 {
        width: 60%;
        margin-top: 4px;
      #getLocBtn {
        float: left;
        margin-top: 4px;
    </style>
    <link rel="stylesheet" href="https://js.arcgis.com/4.3/esri/css/main.css" />
    <script>
      require([
        "esri/Map",
        "esri/Graphic",
        "dojo/domReady!",
      ], function (Map, MapView, Search, Graphic, FeatureLayer, Locate) {
        var map = new Map({
          basemap: "topo",
          map: map,
          zoom: 17,
        // Search
          view: view,
        // Find address
          outline: {
            width: 1,
        var point = {
           geometry: point,
          symbol: simpleMarkerSymbol,
          view.popup.open({
            content:
              address +
              "<br><br> Lat: " +
              Math.round(pt.latitude * 100000) / 100000 +
              " Lon: " +
              Math.round(pt.longitude * 100000) / 100000,
            actions: [
                image: "beer.png",
                title: "get xy",
          search.clear();
          view.popup.clear();
          locatorSource.locator.locationToAddress(evt.mapPoint).then(
            function (err) {
        //############ my first suggestion #################
        // view.on("click", function (event) {
        //   view.popup.fetchFeatures(event.screenPoint).then(function (response) {
        //     console.log(response);
        //     // Access the response from fetchFeatures
        //     response.allGraphicsPromise.then(function (graphics) {
        //       // Set the feature widget's graphic to the returned graphic from fetchFeatures
        //       console.log(graphics[0]);
        //   view.popup.open({
        //     location: event.mapPoint,
    </script>
  </head>
  <body>
    </div>
  </body>
</html>
MatildaOtiede
Hi Christian,
Thanks for your help.
How do I assign the Point graphics on click function so it returns the searched address using the graphic point symbol
As shown below the code displays the location of the search. But I would like the graphic to be used to pinpoint location
Hope this helps a bit.
Thanks in advance
ChristianBischof
Draw polyline | ArcGIS API for JavaScript 4.15
Maybe this sample code could additionally help you achieve what you want.
<html>
  <head>
    <meta
      name="viewport"
    <title>Intro to graphics - 4.15</title>
    <link
      rel="stylesheet"
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <script>
      require(["esri/Map", "esri/views/MapView", "esri/Graphic"], function (
        Map,
        MapView,
        Graphic
        var map = new Map({
          basemap: "hybrid",
          center: [-80, 35],
          map: map,
          zoom: 3,
            geometry: {
              type: "point",
            symbol: {
              outline: {
              width: 2,
    </script>
  </head>
  <body>
  </body>
</html>
KenBuja
MVP Esteemed Contributor
You have a problem with the function arguments not matching the require modules. These have to be in the same order, moving "Graphic" to after "Locate"
require([
 "esri/Map",
 "esri/Graphic",
 "dojo/domReady!"
], function(Map, MapView, Search, FeatureLayer, Locate, Graphic) {
ChristianBischof
<html>
  <head>
    <meta
      name="viewport"
    <link
      rel="stylesheet"
    <style>
      html,
      body {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 80%;
        width: 60%;
      #instruction {
        padding: 15px;
        background: white;
        color: black;
        font-size: 1.2em;
      #instruction2 {
        width: 60%;
        margin-top: 4px;
      #getLocBtn {
        float: left;
        margin-top: 4px;
    </style>
    <script>
      require([
        "esri/Map",
        "esri/Graphic",
        var map = new Map({
          basemap: "topo",
          map: map,
          zoom: 17,
          view: view,
            geometry: {
              type: "point",
            symbol: {
              outline: {
                width: 2,
    </script>
  </head>
  <body>
      </div>
  </body>
</html>
MatildaOtiede
Thanks. This is what I was looking for.
