Arrange fields alphabetically in an attribute table?
1239
6
05-31-2020 02:10 PM
AnitaWeaver
Sorry in advance for asking this but I'm stuck on trying to figure out a simple thing. I want to view the fields of an attribute table in alphabetical order. Is this possible? There are many columns and I don't want to have to arrange them manually. Thank you!
DanPatterson
MVP Esteemed Contributor
There are no existing tools, but you can sort the fields in the table's field view, but it doesn't persist in the table view
... sort of retired...
AnitaWeaver
Thanks, Dan. Are you referring to sorting field values? I know that is possible but I am asking about sorting the names of the fields into alphabetical order.
DanPatterson
Anita, no, just the actual field names, but you can't see the data sorted by field
AnitaWeaver
Can you tell me how to do that? I can't figure it out. Thank you!
Robert_LeClair
Esri Notable Contributor
If you're working with Enterprise geodatabases (i.e. SQL Server, Oracle, etc.) you could create a Database View to do this but the DB View would be read-only (i.e. not editable) but the underlying data would be.
AnitaWeaver
Thanks, Robert!
