Make fishnet that is visible but not editable
567
06-01-2020 03:31 AM
tt1
I'm currently using a polyline fishnet grid to use as a guide when labelling land features. For example, I aim to label 10 grids per day.
An issue I have is that when creating my polygons they keep snapping to the fishnet by accident.
How can I have the fishnet visible so that I can use it as a visual guide but not interactive, so I do not snap to it by accident when creating polygons?
I use both ArcGIS and QGIS to create shapefiles, so need a solution that works across both software.
Note: I need to know the grid ID to keep a log of progress, so I would like a solution where I can still determine grid ID (either visually or by opening the attribute table).
KoryKramer
Esri Community Moderator
It sounds like you just need to turn snapping off for the fishnet layer:
Enable or disable snapping by layer—ArcGIS Pro | Documentation
tt1
Thanks Kory! Do you know if it's possible to enable/disable the snapping status of layers in QGIS?
Robert_LeClair
Esri Notable Contributor
t t - I found this link via a Google search - perhaps this will help you with QGIS.
