How to remove login pop-up window from the analysis widget
397
05-28-2020 01:55 AM
Shalineemishra
Hi All,
        I created a web appbuilder application in which I added an analysis widget for spatial query. Whenever I run my web application on localhost and use the analysis widget , a login pop-up window comes up.Whereas my feature layers and web map are shared to public , still login pop-up comes while using the analysis widget.Please suggest how to remove this login pop-up from analysis widget.
mayankshukla
Hii, did you get the solution for this issue?? I am having same problem.
