michaell@BatonRougeWater.com_brwc
Automating Publishing to a Federated Server
Discussion created by michaell@BatonRougeWater.com_brwc on May 22, 2020
Latest reply on Jun 25, 2020 by michaell@BatonRougeWater.com_brwc
We're trying to script publishing feature services that reference our sde data to a server federated to Portal.
I've had success using getWebLayerSharingDraft to publish a MapImage service to the federated server which seems to reference our sde data, and I've had success publishing a Feature Service but it only seems to publish to the HOSTING_SERVER which makes me think it is being stored in the Data Store associated with the Federated Server and thus is only a copy of our sde data.
If you look at the guts of  _mp.py for getWebLayerSharingDraft you'll see that FEDERATED_SERVER is only compatible with MAP_IMAGE and that FEATURE is only compatible with MY_HOSTED_SERVICES or HOSTING_SERVER.
I've tried to go the route of using CreateSharingDraft but that only seems to be able to access a standalone_server and not a federated server.
Has anyone had any luck?
Outcomes
