Covid19 Cases Feature Layer Data and ESRI DUMPER
970
05-22-2020 02:29 AM
Dunn_Jeremy
New Contributor III
Morning All
I want to download the Covid19 Daily Cases data from here
https://services1.arcgis.com/0MSEUqKaxRlEPj5g/ArcGIS/rest/services/Coronavirus_2019_nCoV_Cases/Featu...
I have tried this way.
1. ESRI DUMPER - Works but then I have difficulty converting the ESRI geojson to something that is usable in a DataBase.
Any thoughts on the best way to convert this output to a SQL readable format ? CSV/TAB delimited flat file for example ?
Many thanks
Regards.
Jeremy.
RandyBurton
You can use the json module to process the geojson.  I was testing the following using python 2.7.  It makes the URL request and writes a tab delimited file.
import urllib, urllib2, json, sys, time, collections
fw = open("covidUpdate.txt", "w") # file to write
URL = "https://services1.arcgis.com/0MSEUqKaxRlEPj5g/ArcGIS/rest/services/Coronavirus_2019_nCoV_Cases/FeatureServer/1/query" # query this feature
# using GET method
query_dict = {
    "where" : "1=1", # something always true
    "outFields" : "*",
    "f": "geojson" }
# results in geojson format
jsonResponse = urllib.urlopen(URL, urllib.urlencode(query_dict))
features = json.loads(jsonResponse.read(),
                      object_pairs_hook=collections.OrderedDict)[u'features']# using the features section
# Header
fw.writelines("{}\t{}\t{}\t{}\t{}\t{}\t{}\t{}\t{}\n".format(
    'OBJECTID','Province_State','Country_Region','Last_Update','Latitude','Longitude','Confirmed','Recovered','Deaths'))
# Data rows
for f in features:
        f['properties']['OBJECTID'],
        f['properties']['Province_State'] if f['properties']['Province_State'] is not None else '',
        f['properties']['Country_Region'],
        # convert timestamp to local time
        # time.strftime('%c', time.localtime(f['properties']['Last_Update']/1000)) if f['properties']['Last_Update'] is not None else '',
        # convert timestamp to GMT
        time.strftime('%Y-%m-%d %H:%M:%S', time.gmtime(f['properties']['Last_Update']/1000)) if f['properties']['Last_Update'] is not None else '',
        f['properties']['Lat'],
        f['properties']['Long_'],
        f['properties']['Confirmed'],
        f['properties']['Recovered'],
        f['properties']['Deaths']))
fw.close()
print 'Done.'‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Results:
OBJECTID	Province_State	Country_Region	Last_Update	Latitude	Longitude	Confirmed	Recovered	Deaths
1	Abruzzo	Italy	2020-05-22 23:32:40	42.35122196	13.39843823	3220	1647	394
2	Acre	Brazil	2020-05-22 23:32:40	-9.0238	-70.812	3343	0	80
3	Aguascalientes	Mexico	2020-05-22 23:32:40	21.8853	-102.2916	586	402	21
I noticed that Provence_State is sometimes null/None, as was the timestamp on occasion.  I kept the time in GMT/UTC, but you can convert it to local time if desired.  It is also possible to use an insert cursor and create a feature layer if desired.
This should give you some ideas.
RandyBurton
If you requested json instead of geojson, you could use the JSONToFeatures  tool (Pro version) to import into ArcMap.
My test script using python 2.7:
import arcpy, urllib, urllib2, json
# using GET method
query_dict = {
    "where" : "1=1",
    "outFields" : "*",
    "f": "json" }
# results in json format
response = urllib.urlopen(URL, urllib.urlencode(query_dict))
with open('covid_update.json', 'w') as f:
    f.write(response.read())
arcpy.JSONToFeatures_conversion(in_json_file="covid_update.json",
                                out_features="C:/Path/to/file.gdb/covid_update")
print 'Done.'
Dunn_Jeremy
New Contributor III
Good Afternoon Randy
Many thanks for the post. After a little bit of re-working I successfully created a script that worked.
Many many thanks. The only issue I have is that the feature layer I am querying has 3466 features in it and the Max Record Count is limited to 1000. Is there anyway to increase this ?
Regards.
Jeremy.
Dunn_Jeremy
New Contributor III
Morning Randy
I solved this by simply running a where statement on the ObjectID's.
Where "ObjectID>1000"
Seemed to work.
Regards.
Jeremy.
