unable to see publish option for scene layer package in ArcGIS Enterprise portal 10.6.1
520
05-19-2020 07:32 AM
divyabathina
New Contributor III
Andrew--Johnson
Is this a building scene layer? If so, building scene layers are not supported until portal 10.7.
thanks,
Andrew
divyabathina
New Contributor III
Hi Andrew,
it's not building  scene layer. It working fine when I publish it to AGOL. but I what it in portal
I have tried to publish directly from ArcGIS Pro . I get below error.
Error - ERROR 999999: Something unexpected caused the tool to fail. Please refer to the error help for potential solutions, or contact Esri Technical Support http://esriurl.com/support.
Error - Failed to execute (Manage Scene Cache).
Informative - Failed at Tuesday, May 19, 2020 2:48:25 PM (Elapsed Time: 11.33 seconds)
Error - Failed.
Thank you
Divya
Andrew--Johnson
To get the quickest resolution I would recommend reaching out to technical support. It appears to be an issue with the Tile Cache data store which a support analyst will be able to diagnose and resolve over phone/screenshare session.
thanks,
Andrew
divyabathina
New Contributor III
Hi Andrew,
Thank you. I will contact the support team
Kind Regards,
Divya
