REST API /updatefeatures geometry attribute (x, y) not displaying in correct projection
1186
05-18-2020 11:55 PM
JackSilburn
New Contributor III
In attempting to dynamically move the location of points on a map, I am using the /updatefeatures endpoint of the arcGIS REST API.
My POST data looks like the following:
"geometry":{"x": 702078.1622769168, "y": 8625267.799537977},
"attributes":{\'device_id\': 1234, \'objectid\': 20...},
The update works successfully, when I use the /query endpoint, the data has changed as expected.
However the map has no points visible when I open the layer in Map viewer. They have disappeared.
Am I mistaken? Does the "geometry" attribute in the request not influence where the point is located?
I even plugged the X and Y coordinate into an online converter and it finds the location successfully.
JackSilburn
New Contributor III
Ok it turns out there is another attribute you need to POST with the "geometery" attribute:
"attributes":{
"device_id":1,
"objectid":17,
"longitude":<insert longitude here>,
"latitude":<insert longitude here>,
"geometry":{
"x":<insert utm converted coord here>,
"y":<insert utm converted coord here>,
"spatialReference":{
"wkid":<insert WKID here>
"attributes":{
"device_id":2,
"objectid":18,
Realising I needed a 'wkid' (well known ID) for the 'spatialReference' key, I did a google for <my city> WKID.
Using this resource, I was able to find the corresponding WKID for my city's Coordinate Projection System, and send it in the POST request.
FYI, to convert lat long coordinates to X Y (UTM) coordinates, I used the Python "utm" module and the 'from_latlon' function, see:
import utm
#Here I loop through my "device list" and convert Lat/long to X/Y utm coords:
latitude, longitude, zone, var = utm.from_latlon(float(<insert latitude>), float(<insert longitude>))
#Insert the X Y coords into the /updateFeatures "data" (payload) string for the request
Just thought I would update my post for anyone that stumbles upon the same issue. This is the culmination of two days troubleshooting.
JackSilburn
New Contributor III
"attributes":{
"device_id":1,
"objectid":17,
"geometry":{
"attributes":{
"device_id":2,
"objectid":18,
import utm
