Delete all table records with special character, # , '
680
7
05-18-2020 09:56 AM
2Quiker
Occasional Contributor II
I have a feature class table that i need to delete the rows with special characters of # , ' or other certain special characters. I have tried the following but nothing happens so I am not coding it correctly, I am in need of some help please.
A2 = "ArcSDE Personal Server/featureclass"
# sql SubName LIKE '%#'
with arcpy.da.UpdateCursor(A2 , ["OBJECTID","Field"]) as cursor:
    for row in cursor:
        if row[1] in ["'", "#"]:
            print ("Deleting record: 'OBJECTID' = {}".format(row[0]))
            cursor.deleteRow()
JoshuaBixby
MVP Esteemed Contributor
Joe, that won't work.  It would have to be written
if "'" in row[1] or "#" in row[1]:‍‍
JoeBorgione
Does Field only contain a special character or are there other characters there as well?  Your line #6 is defined such that the contents of the field is only a single quote or a hash tag.  If you have other characters in that field you may want to consider some regular expression searching.  Take a look here:  Program to check if a string contains any special character - GeeksforGeeks
2Quiker
It does but I am looking to delete rows with just hash tag and apostrophe.
JoeBorgione
Then your line 6 is backwards.  See if this works:
if "'" or "#" in row[1]:
   do something
JoshuaBixby
JoeBorgione
yeah.  that sounds more better!
JoshuaBixby
A different approach would be to use a SQL WHERE clause on your update cursor so that all records already meet the criteria, then you can just delete them without having to check them in Python.
sql = "FIELD LIKE '%'%' or FIELD LIKE '%#%'"
BlakeTerhune
MVP Regular Contributor
I know your question has already been answered but I couldn't resist sharing a couple little tricks I use. First, consider using the @ field name token options to access Esri fields more reliably.
with arcpy.da.UpdateCursor(A2 , ["OID@", "Field"]) as cursor:
    for oid, field in cursor:
        if "'" in field or "#" in field:
            print ("Deleting record: 'OBJECTID' = {}".format(oid))
Also used in the sample above is a method called sequence unpacking to easily assign variable names to your cursor row indexes (field values). This works best with only a few fields.
If you have many fields in your cursor, you can use this helper function to make a dictionary of the values so it's cleaner to access them instead of using the row index like row[1].
with arcpy.da.UpdateCursor(A2 , ["aField", "anotherField", "moreField"]) as cursor:
    for row in row_as_dict(cursor, cursor.fields):
        if "'" in row["aField"] or "#" in row["anotherField"]:
            print ("Deleting record: 'moreField' = {}".format(row["moreField"]))
def row_as_dict(data, fields):
    for row in data:
        yield OrderedDict(zip(fields, row))‍‍‍‍‍‍‍‍
