rtudink
Read lyrx files from packages in ArcGIS Pro Plugin
Discussion created by rtudink on May 13, 2020
Latest reply on May 14, 2020 by rtudink
Hi all.
I'm developing an ArcGIS Pro plugin. I would like to set the properties of a layer based on a layer files (.lyrx) that I would like to provide as part of the plugin deployment.
Therefore I used the LayerDocument class, constructed from a layer file path:
var lyrDocFromLyrxFile = new LayerDocument(@"c:\data\layer.lyrx");
However, this seem to require an absolute path, and therefore this layer file must be installed there by the user.
I can add the layerfile to the solution such that it is distributed with the plugin package. How do I construct a proper path to the resource in the package. Since the package is just a zip-file, and the resource is put with the dlls in the Install folder,  I would expect the following to work:
var dllPath = System.Reflection.Assembly.GetExecutingAssembly().CodeBase;
var layerFile = System.IO.Path.Combine(dllPath, @"Install\LayersFiles\KILOMETERRIBBON.lyrx");
var lyrDocFromLyrxFile = new LayerDocument(layerFile);
However this provides an empty layer definition.
Outcomes
