AnsweredAssumed Answered
vertices remain on clear graphics
Question asked by rajni_sharma on May 8, 2020
Latest reply on May 15, 2020 by rajni_sharma
Hi
My polygon vertices remain when i remove graphics.
My polygons come from db, as well i created new polygons on the spot.
While one of many polygon coming from db always stay editable and one of new polygon created always remain editablle.
the one editable polygon always leave its vertices on removal, even when i used       sketchViewModel.complete();
I tried alot , but didn't get it how to get it fixed.
Any help will be appriceable.
//Clear All method
 jQuery('#main').on('click', '.clear_all', function(){
      //clear all graphics added to graphics layer
      clearAll=true;
      graphicsLayer.removeAll();
  //Double click to delete  boundaries
           view.on("double-click", function(event){
              view.hitTest(event).then(function(response) {
                var results = response.results;
               results.forEach(function(result) {
                if(result.graphic.geometry.type==='polygon'&&result.graphic.layer === sketchViewModel.layer && result.graphic.attributes && result.graphic.attributes.newDevelopment){
                   graphicsLayer.remove(result.graphic);
For making them editable, i use this code below
          view.when(function() {
       // Listen to sketchViewModel's update event to do graphic reshape validation
          sketchViewModel.on(["update", "undo", "redo"], onGraphicUpdate);
          //now the graphic has been added to the graphics layer and the SketchviewMdoel is created
          //to show it as editable when page load
        sketchViewModel.update([newDevelopmentGraphic], {tool: "reshape"});
        });//End View.When
      function onGraphicUpdate(event) {
          // get the graphic as it is being updated
          const graphic = event.graphics[0];
          // check if the update event's the toolEventInfo.type is move then stop move event
          if (event.toolEventInfo && event.toolEventInfo.type.includes("move")){
              sketchViewModel.cancel();
              markersketchViewModel.cancel();
            // If toolEventInfo.type is reshape-stop then it means user finished moving or reshaping the graphic, call complete method. This will change update event state to complete and we will check the validity of the graphic location.
          if (
            (event.toolEventInfo.type === "move-stop" ||
              event.toolEventInfo.type === "reshape-stop")
            markersketchViewModel.complete();
          } else if (event.state === "cancel" || event.state === "complete") {
            //check if the graphics are done being reshaped, printout updated graphic's geometry and reshape stage.
            // graphic  reshaping has been completed or cancelled
              graphic.attributes.state = "updated";
              sketchViewModel.update([graphic], { tool: "reshape" });
       else{
         graphic.symbol = validSymbol;
        }//End OnGraphicsUpdate
// This function is called when a user clicks on the view.
        function setUpGraphicClickHandler() {
          view.on("click", function(event) {
            if(results.length === 0){
              // Check if the new development graphic and temp graphics with attribute named newDevelopment was clicked and pass
              // the graphic to sketchViewModel.update() with reshape tool.
                if (
                  sketchViewModel.update([result.graphic], { tool: "reshape" });
                else if(sketchViewModel.state !== 'active'){
                  view.popup.open({features: [result.graphic], location: result.graphic.geometry});
        }//End setUpGraphicClickHandler
Outcomes
