How can I input a network of streets and create the shortest path to cover the entirety of the network?
1741
05-06-2020 12:43 PM
LisaShealy1
Seems pretty straightforward and that I should be able to do such in Network Analyst, Linear Referencing and/or Create Routes, but I am having trouble figuring it out. Any help would be appreciated. Thank you!
DanPatterson_Retired
Not really that easy.  For instance, can you retrace a road segment?  Do you have an origin? (which can affect the path).
Perhaps you can elaborate on your end goal further.
LisaShealy1
Hey Dan! I am trying to calculate the shortest path to cover a network of
roads for running, so it can be bidirectional or repetitive where
necessary. I have learned that it is called the Chinese Postman Problem.
Thanks for your response and consideration of the issue!
JoeBorgione
Are you talking about what is commonly known as the Chinese Postman Problem?  If so, last time I checked, the ESRI network analyst extension didn't solve for it. I'll give a shout out to and old friend and collegue Jay Sandhu‌, perhaps he can fill in the details.
LisaShealy1
Hey Joe! Yes, I have learned that it is the Chinese Postman problem. I am
amazed that there is not a tool for it, but I guess depending on the size
of the network, it could be incredibly complicated. Thanks for your
response and further looking into it!
