Multiple roles on the same machine?
590
05-05-2020 10:03 AM
MichaelGinzburg
Occasional Contributor II
Can I put ArcGIS Server and ArcGIS Geoevents Server roles on the same machine?
Presuming I have enough resources?
Can I put a Spatiotemporal Datastore on the same machine?
Are there implications with installation and configuration?
Does someone has such an experience?
Thanks!
George_Thompson
Esri Frequent Contributor
That is possible but not advised, especially if it is Production system. They could all end up competing against each other on the same machine.
What is the goal for this configuration on a single machine?
Will it be a physical or VM machine?
Here are some resources to review:
Deployment patterns for ArcGIS Enterprise—ArcGIS Enterprise | Documentation for ArcGIS Enterprise
ArcGIS Platform deployment strategies - GIS Product Architecture - GIS Wiki | The GIS Encyclopedia
Enterprise data center deployment strategies - GIS Product Architecture - GIS Wiki | The GIS Encyclo...
Hope this helps point you in the correct direction?
--- George T.
MichaelGinzburg
Thanks George,
The goal is evaluation of the software.
It will be a VM.
I am aware that the single machine configuration is supported but not recommended by ESRI.
I am mostly concerned with installation/configuration complications.
Thanks again,
Michael
George_Thompson
I would think that you should be ok if you follow the documentation for the configuration of the software components. I would also recommend installing all the latest patches for the best user experience.
--- George T.
